Hi!
I got the 941 error of non convergent non linear iteration. I have followed all the recommendations I saw in the forum to solve this error but it stills appear.
Could you help please? See the files attached. THANKS
which version of Optistruct you are using?
I am using Hyperworks 13.0.110 (64-bit)
If you have access to latest version 14.0 please run on it.Similar example available with finite sliding would help you & try same in your model with large displacement.Refer below link.
http://www.altairhyperworks.com/training/new_feature_videos/14/content/optistruct.htm
thanks Rahul, unfortunately I dont have access to the version 14. Is there not a way to solve it with the 13?
Finite sliding is available only from 14.0 version.
