Hi my name ist Franjo,
i have installed the HyperWorks Student Edition. I can't click on OptiStruct. I have activate the OptiStruct in the Start Menu. Can you help me?
Do I have to install solid thinking?
Hi Franjo,
what do you mean by not clickable?
Could you please elaborate your problem?
When you open HyperWorks you have to select the user profile to OptiStruct.
Do you mean you can't select OptiStruct from the list?
I can select OptiStruct in the start-up list, but I can't click on OptiStruct at Application, as in the picture.
Unfortunately, the image is not accessible.
Do you mean the OptiStruct button as shown in picture below:
Yes, this is what Imean.
firstly, Do you see any error? was the button grayed?
Close HyperWorks application(s) and Please delete setting files on your machine. Follow the link below on how to delete setting files:
http://forum.altairh...iles/?hl=delete
Also, delete .Altair folder in temporary directory. Go to Run and type in %Temp% and click OK (see the picture below)
Franjo,
In the student edition, optistruct is available only through the analysis panel,
The optistruct option in the applications menu is grayed out on purpose, the solver manager that opens in normal versions is not available in the student edition,
however you will see that this does not impair in you using Optistruct in the student edition in any way,
