I am making this example on a reluktance motor i have already created on flux motor and exported to Flux 2d , then I made a CAD for the stator to make the mesh on Hypermesh for making the Data support . The problem showed up when i was making the forces date collection, the collection support isn`t showing the data support which i created and i can´t creat a new forces data collection .i want to know why is that happening although i´m going step by step as the example is showing .
Hi Joseph,
Thank you for contacting us in Forum.
The mesh imported for the stator tooth is in cylindrical or non-cylindrical ?
Thanks and regards
Karun
Joseph,
Can you please visualize the created datasupport and make sure it is exactly at the stator tooth faces.
Thanks
Joseph, Can you please visualize the created datasupport and make sure it is exactly at the stator tooth faces. Thanks Karun
That was the issue .thank you Karun
