Problem with ACU probe
Dear moderator..thank you for reply..
I tried with the inputs u gave me but the error still pops.up..I have followed the instruction as it is in the given manual to run this tutorial model.
Is there any problem if these saved files are in c:/ users/my documents or are there any directory related issues that is giving me this error ..
Dear sir, there is also problem of smpd installation while running my acusolve. can you tell me what the issue is..
I tried to import a parasolid and meshed it by defining boundary conditions and mesh attributes but, when i run it in .log file it shows smpd installation error. Please help me in this regard
What version are you using? If it is V12.0, then there should be instructions in the .Log file about how to install the smpd manually (from an AcuSolve command prompt with administrative privileges, execute the following: acuRun -pb test -mp impi -ismpd). If you are using V12.0.310, this should be automatically dealt with.
This is strange. Try clearing the settings and then try to make your plot again:
File-->Clear Settings
Restart AcuProbe
If you are unable to work with the interface at all, you can also do this through the command line in an AcuSolve command window:
$>acuProbe -cs
