Hi ,
i have a difficult to make a contact interface between a surface representing the soil (shell) and a solid
i need your help please
thanks
Hi FIly,
What is the difficulty are you facing?
could you please let us know the use case?
i want to simulate a spring but i don't know the best contact interface
Hi Fily,
you can try with TYPE7 contact interface.
i do it but it is not good
Fily,
could you please let us know why the results are not good?
what are your expectations?
can you also try with type 24?
Type 24 is good but i have many message : DELETE SOLID ELEMENT NUMBER
