Hi, I'm a new student in using Hyperworks products. Now I'm trying to use Hypercrash to solve the contact force of a pair of gears. and I set up BCs, imposed velocity, and concentrated load.
BCs, only rotation Z has DOF
imposed velocity, function, from 0 to 100 ms, accelarate from 0 to 0.012566. then keep 0.012566 to 200ms.
concentrated load, has a 0.4 N/mm load from 0 to 100 ms.
using Type 7 contact.
unit system kN, mm, ms, kg, User profile Radioss V10.
when I use radioss to solve, I could run this with no errors.
but after I change the imposed velocity to a different value, like 2(0.012566->2), or change the concentrated load, to 10, there are more or less error pop out.
such as, Energy limit reached, Mass limit reached. or time step less or equal to zero.
I know this error shows up because of the engine files setting Card DT/NODA/CST, and maybe the setting in contact setting.I searched on the internet, and see some the errors could be fixed by increasing Stiffness, or Gap. But I tried it and nothing change, Could anyone teach me how to make it right?
it's really nice to have any replies . thanks for advance to everyone.
