I discovered about rQ reading your blog. Is it possible to use it for batch rendering even without solidThinking installed?
rQ is a batch rendering utility that takes a list of files to render and outputs rendered images or animation files, but keep in mind that it is not a standalone application, in order to use it solidThinking must be installed on your system.
rQ is set up automatically when you install solidThinking.
Hope this helps
Adel Matar
Application Specialist
