Hi all,
I have been trying to analyze an assembly of 4 thin disks of different materials.
My problem is when I mesh the individual disks so that I can have at least 3 elements through the thickness (periphery), I get a huge number of elements on the top and bottom faces of the disk because of small element size (0.6667).
If I mesh the top/bottom faces and thickness(periphery) individually by selecting different element sizes ( 0.667 and 10) then most of the elements fail with respect to aspect ratio, element size.
The only thing that works is uniform element size of 0.6667 throughout. But it takes a lot of time to run this simple analysis. ( bottom fixed, pressure on top).
Any suggestions please?
Thanks,
Abhi
