Hi
I have faced this error while I was trying to use Flux e-Machine toolbox.
Would you please how to solve this
The problem come from the circuit that you use. In the case when you sue three current source you need to add a resistance in parallel with one current source (the value is around 1e4 Ohm).
Best regards.
I have done what you said but I still have the problem.
I was wondering if you could kindly check this situation.
Thank you in advance,
The circuit remain incorrect. the resistance you need to put for both current source and coil conductor. keep me informed if this solve the problem. Best regards.
