I want to do Non Linear Material analysis of Plastic component. I have defined Stress - strain curve in TABLES1 card and assigned it in MAT1 with MATS1 card. Analysis is of NLSTAT type. I am getting below Warning & Errors.
*** WARNING # 3003
The Young's modulus calculated from the TABLES1 bulk data entry ID=10
is not equal to the value specified in the corresponding MAT1
(11475.000000 != 10800.000000). This will produce
inconsistant elastic and plastic deformations and may yield unexpected
results.
*** ERROR # 1578 ***
for material id = 2 referenced from property id = 4.
MATS1 is presently not supported for membrane elements (referring to
PSHELL with only MID1 present).
Thanks & Regards,
Suraj
