Installing/Running OptiStruct from a local directory
Updated by Altair Forum User
I trying to run OptiStruct on a computer cluster system, where I can only access and execute files in my home directory. The system is unix. The cluster does not have OptiStruct so I want to install it in my home directory. I tried first copying the (functioning) programm directory into the home directory from another computer. OptiStruct reports this: 'Can not locate installation binaries, please verify the installation' Then I tried running the installation executable in the home directory. The installation went fine but optistruct gave the same error. Can you please advice how to get OptiStruct to work in this case? Is there a way to manually allocate these installation binaries?
1 - 1 of
11
It's better ask your System Admin about this.
