Hi All,
My run has stopped automatically as the computer has shut down due to some reason. Is there any way to restart the run from where it ends? Please can anyone help me on this as soon as possible.
Thanks,
Suresh
Hi Suresh,
If you need to continue the calculation without modifying any definitions in Starter, run the (th Engine file (Runname_000(i+1).rad).
For Example:
•run Starter: TEST_0000.rad
•run the first Engine: TEST_0001.rad
•run the second Engine: TEST_0002.rad > to continue the run after TEST_0001.rad
Hi George,
Thanks for your reply.
I'm not getting the second Engine file as you mentioned. Is the creation of _0002.rad file based on the run time (if the run completes quickly second engine file won't create)? Is it possible to restart the run with first engine file? If any other method available please suggest.
Create a second engine file (xxxx_0002.rad) and try running.
In our Help Menu, other possible methods for restarting a job is mentioned.
