Hyperlink
I need to take the file path of an exported H3D file and paste it in an excel. It should be like, The excel should display 'H3D' and when I click that, it should call that File path and open that H3D file. Can it be done? Any help is appreciated.
Hi Prakash,
I did the same, but the problem is that the file path link is not getting converted as a hyperlink (So that I can directly open the H3D file Hyperview Player on one click of the link)
Have you tried this?
In MS Excel, Goto Insert>>HyperLink>>Existing File or webPage>>Select the H3d file and click OK.
Hi Prakash,
I can do it by this way and get the macro of it. Its is
ActiveSheet.Hyperlinks.Add Anchor:=Selection, Address:= _
'C:\Users\besly_t\Documents\A1.h3d', TextToDisplay:= _
so for using in tcl, I am modifying it as
set A1 'C:/Users/besly_t/Documents/A1.h3d'
*writeh3dtofile $A1 1
sheet Hyperlinks Add Anchor:=Selection
Address:= $A1
set dis [ TextToDisplay:= 'H3D' ]
$cells Merge
$cells Item 1 A $dis
But I am getting syntax errors in these..
I tried like this
set cells [$sheet range a22 n22]
$cells Merge
$cells Item 1 A $A1
$hyperlinks Add $anchor '' '$A1'
But I am getting syntax errors in these again.
I tried like this
$cells Merge
$cells Item 1 A $A1
I tried like this
$cells Merge
$cells Item 1 A $A1
I tried
$cells Merge
$cells Item 1 A $A1
But I am getting syntax errors in these also.
I tried
$cells Merge
$cells Item 1 A $A1
I tried
$cells Merge
$cells Item 1 A $A1
Sorry for the multiple replies... I wrote the code for Hyperlink. Thank You
Hi BeslyD,
You can paste the path of the H3d file along with the file name as a HyperLink in Excel.
When you click on the HyperLink, HyperView player will open with the animation file loaded.
