hi,
how to give damping factor of a material instead of damping coefficient?
Refer attached PARAM card.
Hi Jahnavi,
PARAM, G is used to specify damping coefficient which is calculated as 2*Critical damping ratio.
Can you explain damping factor of what you want specify?
I'm dealing with a skeleton model. so i have to give damping ratio of bones. but damping coefficient means c= 2*damping ratio*omega*natural frequency. Does G represent different parameter here??
G is the Structural damping coefficient.
