font in hypercrash is very small please inform how to change
Before invoking the Hypercrash set the environment variable HC_PLOT_HEIGHT to more than 12
I did not find any environment variable named HC_PLOT_HEIGHT in my environment variables. I suspect you are asking us to follow as follows; my computer>properties>additional settings>environment variables. If it is different then please explain how to change the font. Thanks.
Yes you can set environment variable from that place.
