Dear sir,
i'm new one for the optimization, so some problem occurred during running size optimiztion. please help me....
*** ERROR # 6060 ***
The properties referenced by DSIZE card 1 are not referenced by
any designable element(s).
Hi Yuvaraj,
looks like the property which you had referenced in DSiZE card are empty. Please check if you have any unused properties and delete them and also reference the right design property in DSIZE card.
go to delete > change the entities to property > click on preview unused > look at the status bar > if it says 1 property unused > this could be the problem > click on delete and delete this property.
Thank you sir.
I completed free size optimization then i want to do the buckling based topology optimzation. is it possible?
pls guide me.
with regards,
yuvaraj
could you please elaborate your requirement?
