hello,
I have question regarding optistruct memory allocation.
For a simple analysis I allocate 1500 MB for the analysis. But when I check the output file optistruct selects Current Memory : 150 MB.
What could be the reason for this? Does optistruct choose required memory from allocated memory and send the rest memory out of core?
The picture showing the situation is also attached.
Thanks in advance.
