Hi all,
I am following the hyperstudy e-book, beam.fem example (Hyperstudy 13.0) but I can't access the expression builder (see attached picture).
The nominal run has been written, executed and extracted correctly. What can I do to input the responses I want to investigate?
I can't even use the file assistant (probably introduced in the version 14.0?)
