I need to implement non-linear analysis of a McKibben muscle. The tube is an hyperelastic rubber, that i have modelling as MATX42 and use an NLGEOM analysis.
In my model, I need to apply an initial force of 5N and after a time dt also apply an internal pressure. How do I define these two time intervals?
This is the condintion of my ISOTONIC TEST:
- FORCE F=5N applied from the time T=0 to T=2
- PRESSURE P=0.25Mpa applied from the time T=1 to T=2
Final objective is to obtain a graph that relates the pressure with the stretch of the tube. Thanks
