Submitted by Joe on Tue, 11/03/2009 - 05:36
I am just putting finishing touches our next simulator tool.
We continue to run into a persistent error (error 126) which shows up each time we want to show the model using VisSim Viewer (V7.35A) on a new computer. The dll is linked within VisSim in the Edit > Preferences > Add-on tab, but when the VisSim is loaded I get the error. We are not sure why it is happening. Each time I try to load VisSim this error shows up (on certain computers) It seems that the dll is missing files or ‘something else’ which need to be contained to work with the viewer.
- Can you provide all the correct compiler settings to ensure the dll works with VisSim Viewer.
- The dll is also being developed using VisSim 6.0 environment. Could this make a different?
Thank you in advance
