Error ID 44: Abnormal End/ Missing Normal Termination
Altair Forum User
Altair Forum User
my analysis ends abnormal. How can I fix this error?
Thanks in advance.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    hello!
    it's difficult model.
    why did you use quasi-static analysis?
    i doesn't see spotweld connection.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    Is it correct to use velocity in static analysis?=) What do you think?
  • Altair Forum User
    Altair Forum User
    edited July 2018
    the problem is in connection. i'm not good in altair solvers, i can't repair it, but connections are uncorrect, so i think.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    Welds are not realized. You can use rigids instead.
    or
    Can you run the same in OptiStruct with LGDISP?
  • Altair Forum User
    Altair Forum User
    edited July 2018
    your units are mm, s, tonn-> MPa, N.
    but these moduls are suspicious.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    It is a quasi static analysis and the velocity is very low with 10 mm/min. I thought this should work.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    <?xml version="1.0" encoding="UTF-8"?>image.png.59922cf21d6ac128dc47a39be489d5c0.png
    Thanks. I have changed these values. But the analysis is still not running. Also I have deleted the unrealized welds. But its still not working.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    i did this thing yesterday=) it still haven't worked too)
    i separeted model. i am seaching mistakes in up part (ply).
  • Altair Forum User
    Altair Forum User
    edited July 2018
    @jmey
    it's interesting.
    i did that i said about in up post, but have taken explct solver.
    it works!
    image.png.5d5b8bc21b113483efc81e208a280601.png<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.de85b5b432d94ee85974868c1827a770.png
  • Altair Forum User
    Altair Forum User
    edited July 2018
    @Mrt
    is this without connectors?
  • Altair Forum User
    Altair Forum User
    edited July 2018
    yes, i have written in up post that connectors doesn't work.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    but i didn't check it in explct.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    OK, I think with the unrealized connector the explicit solving will fail too.
    Instead, try with OptiStruct LGDISP.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    it's not my issue=)
    @xyz is topic starter.
  • Altair Forum User
    Altair Forum User
    edited July 2018
    :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'> just a suggestion :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
