I need to export curves using tpl . How can I do that ?
Hi Dipu,
In HyperGraph you will get an option to save the curves as report template(tpl).
Hi George,
Thanks for the reply , but my requirement is to export curves to csv/dat format using tpl .
Or do I need a tcl script for the same ?
There is direct option available in HyperGraph to export curves in csv format.
Can you elaborate a bit more on this ?
Well I know that there is direct GUI option . But I want all the process to be done in background , so that user no need to extract it manually .
You need a script for the same. Please log in and download the script from resource library: https://connect.altair.com/CP/home.html
