I would like to plot certain scalar functions along a path that describes a circunference, not a straight line. Is there any way to do this in AcuFieldView?
Thanks!
In this case, predefining these points as time history points in AcuConsole might be a better option. That way you will already get the actual value in AcuProbe, as calculated by the solver, instead of some form of interpolation done at post-processing level (AcuFieldView). Check 'Workshop #3 or 4 - Convert a Reference Frame Case to a Sliding Mesh Case', for how to create time history points in AcuProbe.
Thank you very much ydigit, I will do that!
You can also do this in acuFieldView using an Open or Closed Curve Path. These are also in the Paths > Create portion of the 2D Plot Controls window.
