I'm currently examining the results of a simple pipe flow case and comparing several solvers. One of the test cases is a simple pipe flow with a mean inflow velocity of 0.1m/s and an outlet pressure of 0.0Pa. The pipe is 0.1m in diameter and 1m in length, the fluid is an oil with a density of 900kg/m^3 and a dynamic viscosity of 0.1Pa*s. The resulting max. velocity should be 0.2m/s, but it only reaches 0.1893m/s. The exact same model and mesh calculated with Abaqus 6.14-3 reaches 0.1984m/s, which is a lot closer to the target value. The pressures differ as well between both solvers. I tried a steady state and transient analysis type (10 seconds in Acusolve and Abaqus), but no difference in Acusolve. I've attached the model and results and I'd appreciate any help leading to a better result. I deem Acusolve to be more advanced in CFD than Abaqus, so the error is probably my model setup.
PS: Somehow, Hyperview only shows the last time step and I'm unable to create an animation. How come? I didn't disable surface outputs.
