I tried prepare similar model, setup was exactly the same but after first contact, snap-fit started deform, this is OK, but snap-fit continue in deformation instead of copy shape of surface as in video above. Does someone have idea, what I do bad ?
Hi Grygarek,
Could you please attach the model and the results
Thank
Vikas
Hi Grygarek, Could you please attach the model and the results Thank Vikas
Hi,vikas
Did you fix the problem?
Hi @tokyo
Please let us know what is the problem you are facing?
Hi @tokyo Please let us know what is the problem you are facing?
actually I am trying to simulate the snap-fit force analysis with a similar model.
The problem is that the slave part penetrates into the master part.
Which file should I upload for your reference?
Thank you in advance.
@tokyo
Please use the file transfer link in my signature to share the model (.fem or .hm) file
Hi, Prakash
I have attached the penetration during slide simulation.
Wating for your responds.
Can you share a picture of contact parameters used?
I have the model file, But no loads and BCs are defined.
Please share the complete model.
