is it possible to change the Parameters minimal density, convergence Tolerance and max. Iterations in Optistruct?
Thank you very much
Regards
Andreas
Use Opti control under optimization to have control on these parameter.
MINDENS,DESMAX or MAXITER,OBJTOL
Thank you
