myproject_0000_0001.rst not found
Hi all,
I try to simulate a crash with hypercrash but when i run the solver. I get the ERROR message (as below)
** ERROR: FILE plot1_0000_0001.rst NOT FOUND
ERROR TERMINATION
==== End of solver screen output ====
==== Job completed ====
I tried to copy and past an old *.rst file, and i get the next message.
** RADIOSS ENGINE 12.0.210 **
** Non-linear Finite Element Analysis Software **
** from Altair Engineering, Inc. **
** Windows 64 bits, Intel compiler **
** Build tag: 0682478_12235120210_2020_0024805_10 **
** COPYRIGHT (C) 1986-2013 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
ROOT: plot_ RESTART: 0001
Thanks in advance for your answer!
Can you share the starter .out file?
0 -
Absorbeur_1_0001.out :
MESSAGE ID : 146
** ERROR : RESTART FILE NOT COMPATIBLE WITH THIS VERSION
(OR NOT A RADIOSS RESTART FILE)
ERROR TERMINATION
Thank you in advance for your help
0 -
Hi Robzim,
Can you share the file using the dropbox link in my signature below?
0 -
It's done
0 -
I am able to run the model without any errors or issues.
What is the HW version you are using?
I ran the model using 13.0 with 110 update.
0 -
I'm using radioss RADIOSS/OptiStruct Version 12.0.210.89
0 -
Hi Robin,
I am able run the same model in 12.0 with 210 update.
Can you change the working directory and run again?
0 -
still asking me for .srt file ....
** ERROR: FILE block120_0000_0001.rst NOT FOUND
ERROR TERMINATION0 -
Robin,
Can you update to the latest patch and try again?
http://altairhyperworks.com/ClientCenterHWUpdateDownload.aspx?pro_cat=HyperWorks
