This year I'm designing a formula student wheel in carbon fibre. The problem that I'm facing is that with some of the layers ( only the layers where the fiber direction is not 0°) show no results in the big part of the wheel. the pictures are in the annexes. Pictures of it are in the annexes. The other plots like the maximum stresses, displacement, ply or bond failure work perfectly. But now i'm not sure if the results are correct due to some results are not available in some layers.
does anyone encounterd this problem also or does anyone know what i did wrong?
Big thanks in advance!
<?xml version="1.0" encoding="UTF-8"?>).thumb.png.37bceb47afb36da53993ac60866a2794.png)
<?xml version="1.0" encoding="UTF-8"?>).thumb.png.074904380932d8fd19c7b443122b7719.png)
<?xml version="1.0" encoding="UTF-8"?>.thumb.png.032745bc810fa3ef34dcb06b48554c93.png)
<?xml version="1.0" encoding="UTF-8"?>.thumb.png.972ebdb8a9a530c8712b4d59e4a73384.png)
