Hallo Guys,
How many CPU is used as Default in Optistruct Simulation?
If thre'is no supplementary parameter, only ONE cpu will be used, I think.
can you please explain more? my Desktop Properties are:
Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.50GHz
Ram 16 GB
64 Bit
how can i fasten the analysis which tricks can be used rather than modelling tricks?
Have a look at my screenshot. With parameter '-nt 4' your job will be calculated with 4cpu in SMP mode.
With the standard direct solving method parallelization is not efficiently used....use PCG Solver (iterative) for linear static analysis e.g. to fasten your analysis A LOT!
Load collector --> card image 'SOLVTYP' --> PCG --> Load Step --> SOLVTYPE ...
Thank you both. excellent explenation. sorry for replying late!
