Altair RISE
Nominate Yourself Now!
General composite pre-proc. for OptiStruct
User: "Altair Forum User"
Updated by Altair Forum User
i have some difficulties regarding composite pre-processing. For my composite analysis (a basic rectangle plate with tension and bending load) I made following requests:
  • CFAILURE (h3d,NDIV=1) = ALL in CASE_UNSUPPORTED_CARDS (for max strn failure criteria or let's say a specified failure criteria)
  • CSTRAIN and CSTRESS (FORMAT: H3D)
  • SRCOMPS (VALUE: YES) for the strength ratio
In HyperView, I can't see my SR-results. The results i get by the listed requests are:
  • Composite Failure (should be design load/allowable load; am I right?)
  • Composite Strains
  • Composite Stresses
  • Composite Strength => Is this the strength ratio?
Best regards
1 - 3 of 31
    OP
    Hi Musti,
    Yes, composite Strength is written to H3D because of composite strength ratio output in PARAM.
    OP
    Hi Prakash,
    thank you for your quick reply. The strength ratio (SRCOMPS) is defined as 1/(Failure index) for max. strn criteria. I've just checked the composite strength (strength ratio) by dividing 1 by the failure index as described in SRCOPMS and the value was correct. I was a bit confused due to the new denotation.
    Regards
    OP
    Thanks for the update Musti image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
