I am trying to view the force vs Time graph after an impact analysis. i get a smooth curve with a peak. I have two questions,
1) How do I get the exact value of the time at which I get Max value?
2) For any other graph how do I check the value of any other parameter at this Time?
Thanks,
Datta
Datta,
There is a coordinate info option in HyperGraph. Using this option you can retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
