I have a question in terms of the ESLM in Optistruct. Are the equivalent static loads calculated and applied to the mesh by the optimizer based on a previos dynamic non-linear FEA or must the ESL´s have to calculated manual?
the loads from the dynamic analysis should be mapped to your optimization automatically, when using Equivalent Static Load Method.
Best Regards
Jan
Attached one is the user guide for ESLM.
how to calculate the equivalent static loads manually according to the dynamic analysis?
thanks!
