hi,
i want to optimize cost of 2 Matrial-Truss (1D, steel and aluminum), i do not know, how / wilch optimization-card shall i creat or change (as response) .
Better -> Screenshot
thanks very much!
9527kun
How is the cost of your material calculated? if it is calculated per mass i.e. per kg, then you can optimize the part with minimize mass as the objective.
Hi Rahul,
e.g. two Material Truss: Steel: Price 20 $/ Kg, Alu: Price 15 $ / Kg:
Obj-Fkt: f (X) = mass_steel * 20 + mass_alu * 15 .
HS-1015: Working with an Internal Math Model
Please go through the tutorial in HyperStudy where material cost and volume are used as responses. That may some how useful for you /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
