Hallo,
i have a 1 component with 500 Elements. i would like to do Sizing Optimization.
i want to assign different property to each element how to do that ? (offcourse without hand because it take alots of time).
Thanks
Hi Tamer,
Do you have geometry?
There is a script available which convets nodal thickness to PSHELL property. but his requires .fsthick file to run. As a work around you can edit the .fsthick for each elements and use the same for assigning the thickness.
Thanks for answere.
i have one component includes only mesh no geometry? why do i need geometry? it should be element based or ?
tamer,
I was wandering if there is geometry available thickness could be mapped to nodes as nodal thickness (possibility).
Can you check the script which I had posted in my previous post?
