In a static analysis, when I'm trying to extract the element forces at bolt locations using ELFORCE command in Optistruct.
The maximum output forces in very high for gravity load cases. What may be the problem?
Is this happening only with gravity load or with any other loads?
can you please check if the units consistency is maintained in your model?
Please note: If you are a commercial customer, you can contact your local support http://www.altairhyp...ortProduct.aspx
Hi Prakash,
Of course , the units are consistent. Its in mm, N and Tonnes. The gravity load is assumed as 9810 mm/s2. I have not checked for any other load cases as, Im primarily concerned about the gravity loads alone.
Regards
