Say I have a rigid body element in a hole, with one independent node in the middle and the dependent nodes being the inside surface of the hole. Now if I apply a force to the independent node and it is pointing towards one side of the hole, how does the force translate to the hole? Will it apply compression on one side of the hole and tension on the other? Or will it just apply a compression on one side?
Cheers,
Josh
