hello
I want to start my calculation but my Radioss icon is disable why ??
http://cjoint.com/?DJnv5QVdJEB
thanks
Hi jeunehomme
What is the HyperWorks are you using?
can you type -both in the options and check if you are able to run the model?
1) i use radioss block 100
hyperworks 11
hypermesh radioss block 100
is it a student Edition HyperWorks?
can you delete the setting files and check if you are able to run the RADIOSS model:
check the link below on how to delete setting files.
http://forum.altairh...iles/?hl=delete
Also, delete .Altair folder in temporary directory. Go to Run and type in %Temp% and click OK (see the picture below)
Please note: If you are a commercial customer, you can contact your local support for a quicker solution @ http://www.altairhyp...ortProduct.aspx
ok thanks
my second probleme is :
my school using HyperMesh 12, how to find the Engine File option on HyperMesh 12
You can find engine file parameter options in Control cards.
in RADIOSS profile, Go to >> Analysis>> Control Cards to create Engine parameters.
Hello everyone
I´m structural analyst from Mabe, I have worked with Altair for more than 3 years.
I want make a complaint about the cancellation of the engine window, In my opinion It is a setback in ease of use of the software
and the worst is that the likelihood of errors is multiplied, we have enough with debugging matters in the day by day, and know this.
I hope the Altair staff consider this and make not only a window for the engine nor a better window.
Regards
