Hello
For a real implementation, I am running simulations of a certain area (parking garage) where the
antenna is only 15 cm above the floor plate. I noticed that the results of my measurements differ
very strongly from the values I find in the simulation.
To check if I had made a mistake I tried to recreate the 2-ray path model using a floor
plate with normal material properties (for example concrete). This was successful because the
resulting power (and field strength) values decreased with 40 dB per decade as we expect from the
theoretical explanation. This of course after the oscillations stop (> critical distance).
However, when I rerun this simulation with lower antenna heights (coming from 5 m to 0.5 0 or even
0.15 m) the results get worse and worse. The lower I place my antenna (but still above the floor
obviously) the worse my results get. At 0.15 m antenna (and resulting prediction height) I get just
over 20 dB/decade. I have graph where I simulated the exact same plate, exact same antenna
location, but with adjusted antenna and prediction heights where you can see this trend.
I feel as though there is something wrong with either the interaction between the antenna and the
floor (incorrect resulting radiation pattern) or that the separate rays don't add up correctly at the
resulting point when they are this close together. I have tried this with several material properties but I still get this result.
Any help would be much appreciated.
Kind regards
Publi
PS: to recreate the results:
Step 1: create database in WallMan, long plate (>2km) of a certain with with 5.5 relative permittivity and
0.01 S/m conductivity.
Step 2: Make SRT project and load this into ProMan.
Step 3: Place an antenna with normal gain and isotropic radiation pattern and arbitrary transmitted
power at the start of the plate. Choose for example 10 m height (also for prediction plane).
Step 4: Simulate it and plot the resulting power from the transmitter to the end of the plate.
Step 5: Confirm that you have 40 dB/decade power loss.
Step 6: Repeat starting from step 3 but now choose a lower antenna height and prediction plane.
Confirm that you power loss is now lower than the first case.
