I am getting some errors “ negative mass on node” and some warnings “check tied interface”. On checking the nodes by ID I can see that these nodes are on the master contact surfaces of TYPE 2 contact with SPOTFLAG=0.
when I set SPOTFLAG=1, simulation can continue to work, it cause a relatively important added mass (mass error=0.15, it is unaccptable) from 1st cycle to last cycle.
I read some discussions about this issue in the forum, but I can not find an answer that can solve the problem.
So, anybody can help me?
Thank you very much!
