Heat transfer
-->Sans titre 1.bmpHi everyone!
I'm studying mechanical engineering i France an I have to make a thermomechanical simulation on a cylnder on HyperWorks 13 by using Optistruct.
I first want to study the heat transfer on the cylinder so I followed this video to set my analysis :
>https://www.youtube.com/watch?v=P-pg0CZtwa8
Unfortunately I have an error message when I launch the analysis...Here is the message:
'Heat GRID 1 used with Component 123 on card SPC 2'
Does someone can help me to solve my problem?... The only differences I have from the video are the dimension: (external radius 20cm and internal radius 12) and the mesh (I attached a pictures).
Thk you in advance!
Fantomas
The simplest answer is that you will have to review the set up again, if you follow the tutorial here exactly - OptiStruct > OptiStruct Tutorials and Examples > Tutorials > Basic Small Displacement Finite Element Analysis:
OS-1080: Coupled Linear Heat Transfer/Structure Analysis
there should be no problems, the tutorial when followed exactly provides correct results.
