How to change menu for Radioss in HW 13 becouse i don't have in Radioss-> Analysis some options like constraint, force. In HW 11 there is normal look of menu.
I attach screenshot.
In Radioss We apply Load & Boundary condiotion using Tools: BC Manager.
Requesting you to use Latest Hyperworks 13.0 Version.
Regards
Rahul R
Sorry, here was rubbish
But as Rahul pointed out, use 13 /emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
Best regards,
Merula
Thank you very much for your help.
So there is no option to made HW 13 (Radioss) looking similar as HW 11 (Radioss)? /emoticons/default_smile.png' alt=':)' srcset='<fileStore.core_Emoticons>/emoticons/smile@2x.png 2x' width='20' height='20'>
PS. I found this BC Manager and it works but how to make loadsteps in this case?
Radioss is used for highly nonlinear Dynamic problems.Good for Explicit analysis.
Optistruct is for Linear & nonlinear implicit problems & optimization.
Previously we use to call as Radioss Bulk & Radioss Block & Optistruct for optimization.
From Latest version we rebranded the Radioss Bulk product name as Optistruct analysis.
Radioss block as Radioss solver.
Hence in Optistruct user profile we need Loadstep to define Type of Analysis. whereas in Radioss we need to create engine file & Output block for the same using Control cards.
Please refer Latest Radioss online Tutorials.
Ok so i can use OptiStruct to create geometry, loads etc. and then change user profile to Radioss and make analysis ?
Everything you can do in Radioss user profile using BC manager.Requesting you to refer tutorials & Example files.
Reagards
Can you please show something here how to create loadstep?
In Optistruct solver loadstep defines type of analysis. Hence it is mandatory to create loadstep.Whereas in Radioss we define similar request using Engine Keywords.
Hence in Radioss without engine keyword run will not go through.Tutorials would give you some idea about setting up those parameter.
Hi
Thank you for the help
Alexandre
