*** ERROR # 1316 *** in the input data
Hey,
I am trying to start a FreeSizeOptimization of just one part of a whole Car.
So i put that part into a new PCOMPP Property and created a Response where i have choosen this Property only.
The errormassage is:
*** ERROR # 1316 *** in the input data:
ATTB must be blank or SUM/COMB for this response type.
Does anybody know, how to fix the Problem?
Greets
From .out file, I see that there is no thickness provided for one of the properties.
Please check and update.
I changed the thickness but the Error is still the same.
What does 'ATTB must be blank or SUM/COMB for this response type. ' mean?
What is the ATTB, that must be blank or SUM/COMB?
Greets
Sorry I can´t share it.
But in the Optistruct--> Reference Guide i found this in the Pictures.
So ATTB is an attribute of a Response, where a further Definition is needed.
And in the .out file it is said, that it is from a Response with massfrac.
In my Model i have only one Opti_Resp: with massfrac and an one Opti_Const: with the upper and lower Bounderies.
I don´t understand, which of these things should be blank or SUM/COMB
Hope this is enough Information for you
Hi @MaK
I can see that you are using the Mass fraction as a response. For this type of response, the AATi should be either SUM or COMB. But in your case, it is seen as an integer. Not sure how it happened.
Can you share the response card image for Mass fraction from your model?
Since you can't share the model, can you edit the deck in a text editor>> find the mass fraction response card>> remove the ATTi filed and check if this helps
Hi Mak,
What type of property are you using for Mass response?
Few properties like PCOMPP are not supported with Mass response>> Property.
Hi @MaK
Can you share the entire .out file?
What type of responses do you have in your model?
