I have created a rubber material with pbush1D.
I need to apply a displacement on element/ node instead of force for running a static analysis.
So how can I define displacement to the element/ node ?
not sure it is something special to the pbush 1d but enforced displacements are defined with analysis - constraints
check the DOF you want to constrain and impose it by giving a number of units length which it should move in your static loadcase.
Best regards,
Merula
See - http://forum.altairhyperworks.com/index.php?/topic/13827-how-to-apply-displacements-as-bcs/?hl=%2Benforced+%2Bdisplacement#entry19852
and other forum topics on this.
