i have a set of 2 clips which are connected to each other. i have set a nodal displacement of lower clip at 2mm. Pls refer the picture
i have setup my BC on Optistruct using SPCADD and used rbe2 rigid elements to pull the lower clip. My solution is converged.
Can you help me with following :
- How do i see the force generated to move the clip (do i need to generate a new control card or which option is there in hyperview for this ? )
-can i view the damage/breakage of clip in hyperview ?
thanks in advance !
Palash
