Hi, I've been using the 9.5 beta, and until recently, every time geometry is selected there's a 3-5 min lag? Any ideas, recommendations how to fix, what could be the cause?
Thanks!
Are you running it on Windows or Mac? Can you also tell me which build number you are using? On Mac, it can be found in the 'Evolve' pull-down tab in 'About'. On Windows, it can be found in the 'Help' pull-down tab in 'Info'. The number I need is 9.5.33??.
Thanks,
