for student edition, you should receive a license file that needs to be renamed to 'altair_lic.dat' and moved to the 'security' folder inside the installation folder.
Make sure your file is correctly located and also that the name is correct. One common error is to rename it and it turns into 'altair_lic.dat.dat' due to suppressing known extensions.
