I've been doing some composite optimization and i'm having problems going from the continuous size optimization to the discrete size optimization. I read the tutorial and watched the video for the example of the Formula-Student-Monocoque but it hasnt helped me.
So after I run the optimization of the continuous size optimization, I dont know what to open next. In which file are the resultes with the new changed conitous size plys? If I open the FEM file the plys are the same as before.
Even in the tutorial files for the monocoque the file: '06_size_konti_complete' is the same as '07_size_discrete' ( apart from the changed TMANUF). So i dont understand why to do the continuous size optimization at all if they dont use the results.
Do I need to change some control cards settings maybe, to get a file with the results?
I hope you understand my porblem,
Best regards
Diego
