I tried to run a job containing PCOMP and a hyperelastic solid modelized with MATHE card. I use a NLSTAT analysis. The run is ok in small displacement but when I use LGDISP I got the following error :
*** FATAL ERROR # 3215 ***
PCOMP in conjunction with PARAM, LGDISP is not supported.
How can I do to perform large displacement analysis with PCOMP and hyperelastic components ?
Thank you
