Hi
I have done crash analysis of a component against a rigid wall/solid but now I wanna do impact test of one component on another. For the crash I created 2 rigid walls and added component nodes to it and created contacts between all surfaces of that one component.
Now i am using 2 solids, one of which is stationary and the other with some velocity. How to constraint the other body? Do i need to make any rigid walls? and what about interface? Do i need it for the solid component?
I am really new to this. Help is needed. Also if there is any tutorial specifically on impact of one on another kindly share or tell the difference between crash using rigid wall and this scenario.
Thanks
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
