Hi Kamlesh and Team,
How can we plot radial and tangential velocity in cylindrical coordinate system ( polar system) in acufieldview? Normally it takes the global system to plot it.
Rohit,
Eicher engines
Hi Rohit,
Please follow the steps mentioned in the attached pdf to plot the velocity in cylindrical coordinate system..
Let us know if this helps.
Regards
Abinash
Hi Abinash
I did not found .fv & .fvreg file in my working dir.
there is only .fvx file .
In AcuSolve command prompt, read your present working directory, please use the below command.
Thanks Kamlesh.
Rohit
Eicher Engines
